Engineering/machining works Nr Hasselt?
Geplaatst: ma 23 sep, 2013 12:37
door dieseldog
Looking for a proper machining/engineering works near to Hasselt, needs to be able to grind back a shaft, build it back with weld and then turn it back to create a new sealing surface.
This is the part.
Can anybody help please?
Also I am a fan of cashy money so if anyone can do this then easy little earner
Re: Engineering/machining works Nr Hasselt?
Geplaatst: ma 23 sep, 2013 17:45
Welding on this part...no thanks. Result " inner hair cracs"
Geplaatst: ma 23 sep, 2013 22:03
door dieseldog
De Rob schreef:Welding on this part...no thanks. Result " inner hair cracs"
Even if it is just building it back up with low amps with a TIG set Rob?
Otherwise will just have to fit the brand new one
Geplaatst: di 24 sep, 2013 12:29
Honestly, I fully agree with Rob.
Hair cracks and trapped air bubbles are hard to avoid here, so is it worth the trouble ?
Geplaatst: di 24 sep, 2013 13:38
door dieseldog
I am going to first try a different approach using a speedy sleeve where by I fit a new seal in the steering box and then fit the speedy sleeve to the shaft from the what would normally be the wrong side, but if it works then it will be beneficial to others to see what I find, otherwise I will be fitting the brand new box, this is going to be more a trial run to see if it can be done?
Now just need to find an SKF bearing and seal supplier
Geplaatst: wo 25 sep, 2013 22:07
Hi mate,
This is what I found on the SKF website:
Imes Limburg
info.limburg@imes.be
www.imes.be
Product category:
Bearings, Units, and Housings
Condition monitoring
Linear motion
Lubrication Solutions
Maintenance products (incl. lubricants)
Power Transmission
Seals
Distributor category:
SKF Authorized Distributor
Address:
Voogdijstraat 33
3500 HASSELT
Phone:
011/28.82.88
Fax:
011/28.82.55
Geplaatst: wo 25 sep, 2013 23:16
door dieseldog
Thats where I was today
Thanks for that Peter
Did you see what I have been upto with my project while I wait for my speedy sleave to arrive
Geplaatst: do 26 sep, 2013 09:36
Are you looking for the "needle bearings "supporting de main steeringboxshaft...?
I have plenthy in stock.€ 15,00 each.... and steeringbox sealkits aswell.
Geplaatst: do 26 sep, 2013 13:09
door dieseldog
De Rob schreef:Are you looking for the "needle bearings "supporting de main steeringboxshaft...?
I will come over when I have the sleeve and get the needle rollers from you Rob as I think I will try this two different ways, sleeve from under and then replace rollers and sleeve as per the norm.
Could you do me a little bit of discount too?
