Re: Te Leen Gevraagd : Diascanner
Geplaatst: ma 21 nov, 2016 12:55
ik heb hier nog een Minolta Dimage Scan Dual III staan, misschien is die niet HR genoeg voor jou en ik heb hem in win7 nog niet gebruikt.
Massa's dia's/negatieven mee ingescand vroeger.
Geplaatst: ma 21 nov, 2016 17:04
Here is quick list of steps needed to run your Minolta scanner on Windows Vista or Windows 7, including 64 bit versions:
1. Install original Minolta software and drivers. Do this without connecting your scanner.
2. Connect your scanner and turn it on with doors closed. It will install using original drivers. Reboot if necessary.
3. Download updated .inf file for Minolta scanners. You can get it here or google it out. Uncompress zip file or put downloaded .inf file somewhere on your disk.
4. Go to "Control panel" and launch "Device Manager". Find your Minolta scanner, right click on it and choose "Update Driver Software".
5. When prompted for driver choose downloaded .inf file. When installation will be finished reboot if necessary.
6. Your scanner should work now
I've used this procedure to get my Scan Dual III running under Windows 7 64 bit. It works fine if I'll launch Minolta software or SilverFast as standalone application. However it fails when called as twain from within graphic software - it says "close your scanner doors" despite they're closed. I don't know if this is specific to Scan Dual III or not, but I'd use standalone mode anyway so I don't care.
Enjoy your scans!
Geplaatst: ma 21 nov, 2016 17:50
die tekst heb ik ook maar dan in 't Nederlands. (met heten en noemen) 8)
