D&G 4x4 Tuning: verdeler voor MadMan Multifunctionele meters
Geplaatst: wo 03 mar, 2010 21:44
D&G is vanaf nu Belgisch verdeler voor MadMan Automotive Instruments.
De EMS 2 is een compacte meter met volgende functies all in 1:
Standard functions:
# Battery voltage with high and low alarm
# Engine running hours with service timer
# Inclinometer and artificial horizon - Only on special order
# Oil pressure loss warning (from OEM oil pressure switch)
# Coolant level alarm
# Ambient temperature
Extra functies mits plaatsen van sensors:
1. Coolant temperature with high and low alarms
2. Oil temperature with high and low alarms
3. Oil/Boost/Fuel/Aux pressure with high and low alarms
4. Exhaust gas temperature with high alarm
Sensors kunnen geleverd worden in complete kits voor Td5 en Tdi motoren!
Andere kenmerken:
* Runs on any voltage from 10 to 30 Volts DC
* Green backlit display
* Ability to record all maximum values until reset
* Voltage reversal and over voltage protection
* Built in audible alarm
* Built in Visual alarm
* External relay output drive to cut the engine or for other uses such as cooling fan control
* Easy to use menu system
* The ability to calibrate your own sensors
* The ability to set the multi gauge to page through your choice of displays at preset intervals or to display one feature only
* The ability to disable any function/s if they are not required
* 1 year warranty
Voor meer info, contacteer ons nu via hendrik@dgtuning.com of check de website van de fabrikant: http://www.madman.co.za" onclick="window.open(this.href);return false;.
Het D&G 4x4 Tuning Team
Standard functions:
Andere kenmerken:
* 1 year warranty
