Engineering/machining works Nr Hasselt?
dieseldog
Woonplaats: Weert, NL.
Ongelezen bericht door dieseldog »
Looking for a proper machining/engineering works near to Hasselt, needs to be able to grind back a shaft, build it back with weld and then turn it back to create a new sealing surface.
This is the part.
Can anybody help please?
Also I am a fan of cashy money so if anyone can do this then easy little earner ;)
Roll on Christmas
Re: Engineering/machining works Nr Hasselt?
Welding on this part...no thanks. Result " inner hair cracs"
dieseldog
De Rob schreef:Welding on this part...no thanks. Result " inner hair cracs"
Even if it is just building it back up with low amps with a TIG set Rob?
Otherwise will just have to fit the brand new one :roll:
Roll on Christmas
Honestly, I fully agree with Rob.
Hair cracks and trapped air bubbles are hard to avoid here, so is it worth the trouble ?
dieseldog
I am going to first try a different approach using a speedy sleeve where by I fit a new seal in the steering box and then fit the speedy sleeve to the shaft from the what would normally be the wrong side, but if it works then it will be beneficial to others to see what I find, otherwise I will be fitting the brand new box, this is going to be more a trial run to see if it can be done?
Now just need to find an SKF bearing and seal supplier :?
Roll on Christmas
Hi mate,
This is what I found on the SKF website:
Imes Limburg
info.limburg@imes.be
www.imes.be
Product category:
Bearings, Units, and Housings
Condition monitoring
Linear motion
Lubrication Solutions
Maintenance products (incl. lubricants)
Power Transmission
Seals
Distributor category:
SKF Authorized Distributor
Address:
Voogdijstraat 33
3500 HASSELT
Phone:
011/28.82.88
Fax:
011/28.82.55
dieseldog
Thats where I was today :D
Thanks for that Peter :thumbup:
Did you see what I have been upto with my project while I wait for my speedy sleave to arrive :oops:
Roll on Christmas
Are you looking for the "needle bearings "supporting de main steeringboxshaft...?
I have plenthy in stock.€ 15,00 each.... and steeringbox sealkits aswell.
dieseldog
De Rob schreef:Are you looking for the "needle bearings "supporting de main steeringboxshaft...?
I will come over when I have the sleeve and get the needle rollers from you Rob as I think I will try this two different ways, sleeve from under and then replace rollers and sleeve as per the norm.
Could you do me a little bit of discount too? ;)
Roll on Christmas
